trainwrecker22
Thread starter- Joined
- Jul 27, 2014
- 28
I have a 96 350 with a mercarb 2 barrel. The issue is when i run at WOT I can only run for 7-12 minutes before it starts loosing power. If I drop down to 2300-2500 rpms for a few minutes I can go WOT again. I rebuilt the carb and thinking I had a float or pump issue but that did not solve the problem, I changed the fuel filter, and checked fuel pressure. I am getting 15psi. I am sure I am missing something quit obvious. If you can point me in the right direction that would be great. Thank you Kevin.
