Re: worst boat ramp story
Boy, these stories make you cringe don't they? Well, the worst i've had at the boat launch isn't nearly that bad, but aggravating for sure. We had gotten used to our old shallow water 17' Dargel flats boat and loading it in and out of the water every weekend for about a year. But when we sold the little boat and bought a 22' deep vee offshore style boat, things at the boat launch were a little harder. First thing that we fought was getting the trailer deep enough in the water without dropping off of the bottom of the ramp...our local spot is made with inshore boats in mind. It seemed if we backed in far enough to land the bow on the rollers the boat would drift around over the fenders, and we were scared to death to pull it out at this point. So we pulled the trailer up a little, then the bow rail hits the rollers before the hull, lol...so here we are in the water trying to lift the front of the boat to get it started. Eventually we learned to leave the trailer deeper in the water, and keep the boat centered in the slip with a gaff or net handle while the truck pulls it out, insuring it lands between the fenders. Other than that, we've had a flat tire on the trailer backing into the water because of someone's discarded boat plug shoving into the tire...making it very interesting to pull the boat out when the leaf spring was hung on some concrete down there. My brother's 2010 3/4 ton Chevy Z71 was spinning all 4 tires trying to pull it out. Wound up docking the boat and fixing the tire before we finally got the boat out of the water.
