Mark42
Thread starter- Joined
- Oct 8, 2003
- 9,334
The 85hp Force on my Bayliner has no power tilt. Even worse, they didn't even include a slave cylinder to help lift up the 300lbs of motor when you need to tilt it.
I often found myself in a situation where just tilting up a few inches would have been a big help. But instead, I had to use the boat hook fully extended and use it to push off the bottom into deeper water. Not fun when the wind or current are against you.
So I was looking at the tilt locking mechanism, and its just a flat stock bar with a notch cut in it for full up tilt lock. Wondering if anyone has modified or replaced this bar so that the motor could be locked in 3 or 4 locations. That would be great for backing away from beaches, pulling in to shallow locations, anywhere slow going in shallow water is needed.
I think I'm going to keep this Force for a while, and this is something that needs addressing.
Right now I am not going to invest a few hundred dollars into a used power tilt off ebay with questionable condition and useable life. Right now I'm looking at low budget solutions to shallow water running with this motor.
