Woodruff key
Sudshunter
I've searched everywhere and can find nothing on why would the woodruff key that keep fly wheel on keeps shearing off . It's the 1957 evinrude 18hp outboard ! Wrong size ?maybe I have wrong part number I don't know. Any help would be appreciated, thanks in advance!
gm280
:welcome: aboard Sudshunter to iobats....
What you are talking about actually points to one main thing. And that is you are not torquing the flywheel nut to the required specification. If it isn't torgued properly is will do exactly what you are talking about. So either find out the actual torgue for it or post the model number and someone on these forums can tell you. But that torque is going to be very high. You will nedd a good torque wrench to do it correctly, or you could get a loaner from an atuo parts store for that job. JMHO
F_R
Honorary Supreme Mariner
The flywheel and crankshaft tapers MUST be in good condition and not buggered up from repeatedly shearing keys. The tapers MUST be shiny clean and dry. And you MUST use a torque wrench to tighten the nut to 40-45 foot pounds.
The key is primarily for alignment. The taper is for locking the flywheel to the crank. If you didn't use a puller to remove the flywheel, it was way too loose.
Constant shearing of the key will bugger up the keyway and key seat.
Follow the instructions from F_R.
oldboat1
^^agree with the above suggestions -- rounded edge of the key goes into the groove on the shaft, and the flat edge needs to be parallel to the shaft (vertical) -- does not follow the angle of the shaft taper. believe the oem key would be 766437.
