bruceb58
- Mar 5, 2006
- 30,790
Re: Wood Flooring Install Question
I am not anticpating any problem. I have good drainage around my slab and I have a vapor barrier underneath it. I know a lot about the house since I built it(acted as the general contractor).I don't really have any expertise to comment on the adhesive options (sounds like you have sources that do have that expertise), but I would be leery about expecting anything to seal out moisture from the inside if it is permeating through from underneath, and that almost always (in my experience) ends up being problematic. My suggestion was just a quick and effective check to rule that out.
