I was wondering if any of you have had ths problem before or may be able to help.
I have a 1999 Evinrude 115. I was running full throttle when all of a sudden, the check engine light came on and the alarm sounded. The motor shut completely off. It did not go into the S.L.O.W mode at all. The motor will crank and start but only briefly. It will not stay running long enough to put it into gear. It just fires and shuts down again with the check engine light on. The fuel pump is activating and pressurrizing as I checked both. By the way, the motor was not hot at all and was running great. I also checked the fuses at the ECM and they all looked fine. Some have said that it sounds like a relay however I am not sure how you can check a relay on he ECM.
Any advice would be greatly appreciated.
