Won't start hot
Woodyee1129
I have a 2002 Johnson 50hp 2 stroke. When motor is cold ( for instance sitting all week) motor will start and run fine. After driving boat to an island on the lake , maybe 1/2 hr ride, and staying at island for a couple of hours motor will not restart. The motor cranks over fine but will not start. Thank you in advance for any ideas you may have.
flyingscott
the motor is no longer hot after a couple of hrs have to go through your cold start procedure
Woodyee1129
It won't start any way I try. But next weekend after sitting it will start fine. Not sure what could be causing this.
flyingscott
then we need more information is the boat new to you did this just start happening does the motor sit tipped up also model# and year
gm280
Woodyee1129, first of all :welcome : to iboats. Great having you join us...
So you have an engine that will easily crank when totally cold but not cool, and refuses to crank when even a little warm. A few things to check. When it cranks but doesn't start, are you getting spark? You can verify that with a spark tester available at most any automotive parts store. They run about a few dollars and will let you know really quick if spark is your problem. If the spark is there, then is the primer bulb still firm when it refuses to start? Could be you have a fuel delivery issue. Mix up in a little bottle a mixture of 50:1 fuel/oil and squirt some in the carb(s) to see if it fires. If so you have a choke/fuel problem... After trying those test, post back on here for us to read so we can offer better options... JMHO!
Woodyee1129
The issue started toward the end of last season. I did not check this past time but it did have spark last year when it. Last year I replaced the primer bulb and fuel line. Also fuel filter. The bulb does stay firm and after I was towed back to the dock I went and purchased a can of starter fluid. A very little squirt and she fired right up. Not sure if it was that or that it had sat long enough to refire.
boobie
As said above the next time it won't start use a spark checker. Set it to 7/16 ".
