1000dollabill
Thread starter- Joined
- Aug 5, 2007
- 20
Re: Won't Reach WOT! Please Help!
Yes, the boat has two speedos, and speed was verified by gps as well as paced by another boat. The tach reads normal without load, how could it be off with load? There's no way it free revs to 6,000+ rpms. the block numbers (not intake) correspond with a 351w. Tried the 302 firing order just for shi+s and giggles, wouldn't run. The block, heads, valve covers, intake are all sporting the factory Indmar stamps and silver paint. The carb has been gone through a dozen times, as well as the ignition system. The trans has an ID plate "borg warner 1:1." The prop is stamped 13X12LH. Not sure what the boat weighs, but there is little to no foam in it. The trailer is squatting a little bit, probably because it is an older single axle designed for a shorter, smaller boat. Previous owner said it ran 50+mph.
If it had a vacuum leak it wouldn't idle as well as it does. Checked vacuum last season off the intake. Also did an old school propane test to check for leaks.
It's backfiring out the exhaust because it doesn't actually run at WOT, merely 3/4. If I push it to WOT it howls and will eventually ignite the unused fuel in the exhaust.
Every boat I've owned has been gear limited, could be run at WOT all day if you were the gambling type.
I'm fairly convinced it's the prop causing the howling. From what I've read cavitation produces a vibration and sound. The prop has pitting, edges are rough, and the blades surfaces look like some took a torch to the center of each blade.
I'm just west of Atlanta. Any local gurus want to take a spin?
Just a note I've rebuilt my own motors and transmissions for about 10 years now. Cars, trucks, atv's, and a couple lawn mowers. My pops has been an auto mechanic for 30 years and he's stumped.
The guys at SKIDIM (Discount Inboard Marine) worked with me quite a bit last season, said the only thing left is the prop.
I'm buying a prop tomorrow, worst case it's always a good idea to have a spare.
The motor runs perfect, so I'm looking farther down the drive line.
Not dismissing suggestions, but some contradict my tests last season.
