New here to this forum, also my forst OB motor. It is a 85 Johnson 90 HP V4. J90MLCOS The VRO has been disconnected, running on 50:1 pre-mix. When I got the motor it wouldn't crank, turned out to be a blown fuse. Starts right up every time now. Motor idles and goes into gear fine but when you get to about 1/4 throttle, that's all she's got. It just bogs down and surges a little but that's it. So far I have rebuilt both carbs, fairly certain they are completely clean. New fuel pump, using a portable gas tank, new lines, new bulb. The bulb does not go flat. What I have discovered is that if I pull off the top starboard plug wire nothing changes, I do get zapped a little. If I pull off any of the other 3 wires it drops RPM. I am waiting for the manual, it's ordered. Any suggestions on what this could be?
