Wont crank over
heyttown
Everything is hooked up correctly, put it in the watre this morning, and my control box made a different chirp(instead of the normal chirp when you turn the key over),Sometimes it didnt chirp at all. I checked to make sure the lanyard was all the way in,and that I was in neutral, just by the sound its making, it has to be electrical.It has done this before, I drove it back home and it fired right up in the driveway, so I cant pinpoint what the problem could be, especially since it doesnt do this every time, last time this happened was 4 months ago, And Ive prolly used the boat 30 times since then, and no problems until today.<br />Any ideas?
Joe Reeves
Re: Wont crank over
I believe that what you're saying is that the engine's electric starter makes no attempt (at times) to crank the engine.... as compared to the engine cranks over but will not start.<br /><br />If so, that could be caused by dirty and/or loose battery cable connections at the battery. Remove, clean, and re-install them, tightening them with a wrench or pliers... not with your fingers.
heyttown
Re: Wont crank over
Thanks Joe, I visually inspected the battery cables at the ramp, but at 5:30 in the morning everything looked good, and felt tight, I took your advice and cleaned the post and every connection at the battery, 20 minutes tops, and she fired right up...I was suprised the terminals didnt look that bad, but I figured it couldnt hurt to clean them anyways.........<br />Thanks again
