wiring where it goes
River Monster
I have a 1989 force 85 hp 2 stroke.
i need to know wherre all the wiring on the coil side of the boat goes on the 12 screw strip.
a friend thought he was helping me by cleaing all the connections. he unhooked them all and has no ideal where they go back to.
can any one help me.
thanks
Josh P
Re: wiring where it goes
check on top by the flywheel there should be a wiring diamgram. if not i will try and get a pic of mine i have a 120 so youll have a couple less wires but same difference. unless some one else chimes in to help sooner
River Monster
i would be thankful.
what is the diffrence between a dva meter and a digital multimeter
Josh P
i forgot to get pics of the wiring get a pic of what you have i will be able to help by memory, as im at work till 11 est and will be bored, if not ill get the pick tonight when i get off. Not sure the difference, i just know you need a dva to test outboard ignitions. i think becuase the voltages pulse so quickly you wont see the reading, the dva slows the reading down for the meter to be able to read it.
Josh P
Here try this website. scroll down a bit and youll see connections for 2&3 cylinder engines. try that out for the time being let me know
CDI Electrics
