johnson1st
Thread starter- Joined
- Sep 6, 2005
- 13
I have an 87' bayliner bass boat, 50hp Force is junk, took off and put this johnson 40 on. Trying to wire up. the key switch on bayliner has more than I'm used to: (got engine to turn over, but no fire to plugs?)<br /><br />bayliner switch:<br /><br />B = Battery<br />S = Selenoid "S" post<br />M = points/condenser<br />M = points/condenser<br />I = Not sure???? put to temp sensor<br />C = Not sure???? put to elec. choke<br /><br />p.s. this 40 does not have a generator...<br /><br />on the johnson, i got a manual, all wired up per<br />schematic...wire going to cut out switch on motor is a ground going to "I" post on selenoid...seems strange, I would think that the black wires on cut out switch with fiber washer means "Hot", I would think the "I" wire on selenoid goes here. Anyway no fire....anyone have ideas??? How do I get power to points??? Thanks.
