wiring help for my 140 johnson
usstickers
Hello all..
I have a 140 horsepower johnson motor that I bought used. I don't which wires on the ignition switch connect to the motor wiring. The back of the ignition switch has a letter at every terminal if that helps us. I have pictures of all the wires and sensors that came with the motor that I can upload if necessary. Any help would be greatly appreciated. This is my first post on this forum, so if I did something wrong posting let me know. Thank You.
Chris1956
Honorary Supreme Mariner
Your answer would depend on the year of the motor. Modern motors have ignition systems that run off the alternator. A black/yellow wire would be grounded to kill the spark. Real old motors had magnetos. Motors in between had other kinds of ignitions.
emdsapmgr
There are some old color factory wiring diagrams hiding in the topmost post on this Johnson/Evinrude section. That first post is called "top secret files". You will find wiring diagrams in there for some units-that's the best help I can give, since you did not post the year of the 140.
usstickers
I hope these pictures help. I did find that the motor is in fact a 1993.
Chris1956
Gee, I am not sure I really understand your question. Your motor should have a single large red plug from the boat harness to the motor.
usstickers
The end with the big red plug is plugged in but the opposite end of the wires coming out of the red plug are not plugged into anything. I bought a boat from one person and the motor from someone else. So it's all of the wires coming out of the big red plug that need to be wired to the boat.
usstickers
Wow! Thanks Fed. I think that is going to do the trick. Thank you so much. I'm only 8 wires from getting in the water.
I will let you know how I do.
usstickers
Gotta Thank You again Fed, all wires are connected and the motor turns over great! Now what may be the stupidest question i have ever asked about a boat. Where do I connect my gas line?? The motor came with an oil tank system that has 2 wires on it and I found the wires on the motor to connect them to. As for fuel there is no fitting to connect to that I can find. There is a normal fuel filter on a piece of hose in the motor casing just hanging there. The line that comes in from the oil tank setup could plug right in to it but where does the gas line hook up? The boat has an onboard fuel tank and the previous owner has the typical 5 gallon outboard tank fitting and bulb ready to connect to a motor. Here's a few pics to look at. And whats with the red arrow switch and schrader valve, I have never seen that before.
Fed
Gas line hooks up to the white filter.
Oil line (the one with the bolt in it) hooks up to the VRO pump if it hasn't been disconnected.
The thing with the red lever is the fuel primer, electrically operated solenoid valve by pushing the key in to activate. When operated it opens and allows fuel to squirt directly into the intake by-passing the carbys for cold start.
Turning it at right angles opens it manually for rope start, it's in the normal position at the moment so leave it.
Make sure the tank has got pre-mix fuel in it at 50:1 before you go any further.
You will have to esablish if the previous owner was using the VRO or had it disconnected & running on pre-mix.
usstickers
The gas filter contained a few drops of blue fluid so that means most likely premixed right?. I cant find any other places to hook up an oil line on the motor. The clamp on the oil line bolt looks like it was tighter than it would be if just stuck in there to keep oil line from leaking out while traveling. I'm gonna premix some fuel as you said at 50:1 and test it, I think it is setup that way. The guy who I bought it from keeps his boat at the marina where some the guys from the Wicked Tuna Show on tv keep their boats. I am going to contact the mechanic at the marina and see if he knows if the previous owner premixed. Thank You AGAIN. I would love to hear it run today! I will update you.
usstickers
Now we have very good spark in all 4 cylinders good plugs. bypassed the oil tank, put in 3 gallons of gas mixed 50:1. i am flooding the engine now. It will start on starter fluid as soon as i turn the key. So it's fair to say fuel is the issue. I do not have the throttle or transmission cables because they are way to long by about 5 feet. I did set the carb linkage at a few different spots and tried to start the engine but did not work. I need to figure out the flooding issue.
usstickers
I removed all spark plugs and let the air dry out the cylinders for a couple hours. It did the trick, everything dried out and I got it to run in about 2 minutes. Now I need control cables before we can test drive and hopefully enjoy the summer. Thanks again Fed, I could not have done it without you!
