wiring harness?
maagee79
I am attempting to convert my keys to a on off rocker switch with a momentary start rocker switch. I have everything installed lights work and everything when I turn the on off switch on but when I try to start it doesn't start and the negative battery terminal got real hot. Not sure what I am doing wrong. I am under the impression that the orange wire isn't used for anything is that correct? I have it hooked up to a negative post is that right? I hope I can get this figured out today so I can be on the water tomorrow. Thanks
this might help its a 1975 150hp incline mercury.
NYBo
Re: wiring harness?
Sounds like you somehow wired in a dead short to the starter.:eek:
What does this orange wire connect to at the other end?
maagee79
Re: wiring harness?
Idk there is not an orange wire leaving the harness in the motor.
