wiring for a kill switch
aspendad
New to the forum and new to boating
It haunts me that it only sits in the drive and not the water
I bought a 1968 Waconda 16ft with an 64 speeditwin #28402. the motor fires right up and sounds good and strong but the key ( 3 prong, new)
does not shut it off. all the switches were corroded so i am replacing them. The only unsure thing is the kill switch. Is that not just an open circuit the the switch closes to ground? If so, where does it wire up to? Something and the ground yes? Pardon me but every thing i know about outboards and boat wiring I am learning here. so thanks!
Is it from the magneto to ground? What and where is the magneto. And isn't there just a basic, simple wiring diagram?
thanks for any help you can send my way
Kelly :confused:
Silvertip
Honorary Supreme Mariner
Re: wiring for a kill switch
You have the wrong ignition switch. You bought it at an auto store I presume. That switch is for a battery igntion system like the one in your car. They work backwards from a swtich for a "magneto" ignition and those switches typically have five or six terminals. So you don't need a kill switch (actually you should) but you do need the correct ignition switch. On that switch the coding is as follows:
S = Start solenoid
C = Choke/primer
A = Accessory (active when key is on)
B = +12 volts to the switch from the battery
I (or M) = Magneto
M = Magneto
On this style of switch, turning the key off connects the two "M" terminals or the "I" and "M" terminals which shorts the ignition to ground to kill the motor. If you add a lanyard type kill switch the two wires connect to those same two terminals.
aspendad
Thanks Silvertip
Of coarse I have the wrong switch! Should have come here before the the purchase. I just removed the old one and took it to the local boat store and just picked a new one off the shelf. Kinda erks me too! :mad: I told the "Master tech" on duty exactly what motor I had. you would think he might have said something yes? Any how, I will go get the correct one in the a.m. and take back after it
thank for your input I'm sure I'll be back:p
