Re: Wiring Diagram
If your charger is rated 24v, yes, you can leave them in series to charge. Be sure to check the docs from the charger manufacturer. There are a couple of multi-bank 12v chargers that can be setup to charge each battery independently, even while they remain in series. They have independent, floating grounds. But these are few and far between, and if you try that with a charger that has common ground, you will have a big problem.
