Does anyone have a wiring diagram for a dash mounted engine trim switch?
The motor in question is a 1998 DT225.
Here's the situation. This boat has three trim switches. One on the motor cowling which is pretty normal, one on the throttle which is also pretty normal but I have a third switch on the dash. Neither the throttle nor the dash switch work. Replaced the dash unit yesterday ( it was all rust ) still nothing. I know I replaced the wires correctly as I marked them prior to removing. And yes, I am electrically challenged - to the max !
If you want the complete scoop I also posted this question in the electrical section - too much to do again.
