Wiring diagram for 3.0 mercruiser
achris
More fish than mountain goat
The limit switch connect directly into the trim pump harness. The gauge sender connects to wires in the engine loom. That may be through a connector mounted on the engine, yes...
Chris....
grizzreaper
Hey Chris I know this is a old thread. I had to rewire the ignition again. Some how I got a ground that was a hot wire. Do I splice the battery wire before ignition which makes sense so I don't need key on for lights, blowers, n fish finder. Or splice off ignition then to the buss bar.
achris
DON'T put non-engine wiring on the engine harness. Causes too many problems down the track. Run a new 6mm pair (red and black) from the switched side of the battery switch, through a 60A circuit breaker, to a red and a black terminal block. Run all your lights, blowers, sounders, GPSs, bilge pumps, noise makers (ghetto blasters), two-way radios from those terminal blocks. Leave the engine harness with just engine stuff on. I would add only a fuel gauge and an hourmeter to the engine harness, nothing else.
Chris.....
