Fuzzy-wuzzy-3
Thread starter- Joined
- May 10, 2010
- 3
I have a 92 Lowe boat with a minn-kota 24v trolling motor which has a three prong plug. It has panel for the trolling motor plug and the tilt switch. It also has a three-way switch for Charge 12/24 and 12/24 Run with 12v in the center.
The wires for the 3-way switch have been cut and respliced and one was not hooked to anything. Is there anywhere I can find a wiring diagram to make sure I can re-wire the 3 way switch properly?
There are two red positive wires and two black negative wires coming from the two batteries (one black and one red from each battery) that go to a 4 prong plug. The opposite plug then goes to the three-way switch.
I do not know where the two pos and two neg from the four prong plug are attached to the switch and where the two red and one black for the trolling motor plug ar attached.
The tilt switch wires come from the motor controls and are not affected.
I have looked online, but apparently not in the right place. any help appreciated. I bought the boat last year and am the third owner.
