I purchased a panel with switches and a fuse block. It's a little different from the guides I'm seeing on here so I'd like you guys to see if I'm on the right track as far as setting this up.
All the switches are illuminated except the horn.
I will only be using the bilge, nav/anc, horn, switches and a 12v acc. plug.
The panel was missing the nav/anc switch so I purchase a new one and installed it.
1. Are the switches all grounded because they are illuminated?
2. I'm a little confused about the horn. Do I run only one wire from the horn to one side of the switch then a wire from the other side of the switch to the fuse block?(and of course the ground to the ground block)
3. My nav/anc switch has 8 plugs and I can't find a diagram for that one. Any idea on the wiring for that one?
4. Do I need a circuit breaker between my battery and the fuse block?
Here's my diagram I drew up.
And here's that nav/anc switch.
Thank you for your help!
