MisAdventure
Thread starter- Joined
- Oct 17, 2010
- 50
have 6 guage wire, going to run it from front of a 14 foot boat back to t/m on back of boat. Want bat in front to help with weight....
t/m has rings on wire....dont want to cut the t/m wires....
prob put rings on the extension wires I got....then run bolts through both rings to connect....
can I use a block of wood....mount a positive bolt and a negative bolt through the wood....slap another peice of wood on the back of it to keep bolts from touching anything...then screw it into a bench....leaving the two post exposed sticking up in the air.......
then, run wire from bat back to post connecting with ring to post, throw the ring from t.m wire on post...bolt it down tight....
that way it is still easy to take every thing out except for my home made bat post.....
or is this not safe?
