I am winterizing my 2004 175 Bayliner with Mercruiser 3.0 Alpha One by myself for the first time, (Marina not an option this season) I started by trying to fog with engine running on the muffs the engine cranks fine but won`t start, it ran find two days earlier when I removed it from the water. The engine has a "Single Point Drain System" so I pulled the two blue hoses and lowered them into the bilge below the point where they connect to the engine, I would say approx, 2 quarts of water drained out, is this right? is there any other procedure other that changing oil and filter and gear oil that I need to perform, I have found many conflicting opinions regarding adding anti-freeze (air doesn`t freeze or expand with cold) I live in Ontario Canada, winter temps may drop to in excess of -30 degrees
