- Apr 17, 2002
- 71,490
Re: Winterizing Merc 5.0L EFI's While In Water
Ayuh,... Merc is Still using the same motors, 'n same knock sensors... Today...
The knock sensor is actually mounted on a brass "Y" if that makes any difference. Perhaps due to a clearance issue for the sensor? Maybe using a longer stem and a "Tee" would work. These engines are 305 CID. Merc quit using them for a couple of years but brought them back in 2001. I think Merc used a GM base block up to 1997 but not sure where the got the 2000 and on.
