bruceb58
- Mar 5, 2006
- 30,838
Please ...nobody follow this advice.And, you DO NOT have to drain an engine before using A/F!
You must be thinking of someone else. My GF does not have an RV and not sure where I said anything about them.bruceb58 you may want to talk your GF into running a couple jugs of 192 proof polish whiskey ( Polmos Spirytus Rektyfikowany) into the RV water system. Then when done, it makes one heck of an octane booster for your drag car or your coctails.
Thank you all for your help! I will try to get the marina to refund me what they charged me for winterizing the engines.
Ayuh,..... Sounds like you ain't found a real boat mechanic, yet,.....
The 1st step of any, 'n all winterizations is Drain the block, 'n manifolds,....
Once Drained, the coolin' system fills from the bottom up, if yer pumpin' in antifreeze,....
Countin' on the t-stat be open is a fool's chase to a frozen busted block,....
The manifolds would probably survive, as any water, or antifreeze the block don't take, by-passes out the manifolds,...
Or, you can just Quit after step #1,..... No antifreeze,... Air don't freeze,......![]()
So enlighten us...how do you do it?The guy doing anti-freeze in his drive way must drain his cooling system first.
But this post wasn't started by "the guy in the drive way"!!!
So, Bondo. As a seasoned boat mechanic, I really take your statement as an insult! This bunch is so narrow minded it's a shame! Your theory on the block must be drained is total BS.
...Your theory on the block must be drained is total BS. ...
