My new powerhead has less than 3 hours on it and still is in the 25:1 break in period. Do I still need to fog the engine or is this mixture enough to<br />protect the cylinders. Wouldn't fogging oil + this mixture be an overkill? Since I live in NY, its getting very close to pulling her from the water..<br />Also - each year I would use a tank to flush the engine. Never seemed to get enough water to the head using rabbit ears. Since they installed a new water pump I figured the lower unit was pressure tested and in tip top shape. I really hate using the tank thing because it takes time to set up plus it leaves a ton of oil on the engine and in the tank. Any tips on rabitt ear flushing. Thanks for your reply.
