I have a 1987? S#0B203140 Sail drive that I got this year, runs pretty well. What I'd like to know is on winterizing this motor...
1: Can I remove the prop and run it in a tank (garbage can) of water since there is no way (that I know of) to hook muffs to it?
2: Is it best to change the lower unit oil now or wait till spring?
3a: When running fuel with sta-bil in it. How much / long do you need to run to get the treated fuel into and through the carb?
3b: Is it better to run the engine out of fuel or leave some treated in the carb / bowl?
I plan on fogging it as well. This will be stored outside in Indiana winters on the boat. Any other tips are also appreciated.
Thanks,
Nik
Thanks,
Nik
