Rranger
Thread starter- Joined
- May 18, 2009
- 478
120 hp Mercruiser 1973. At the end of the heat exchanger closest to the stern there were two plugs. I removed the back one and fresh water came out. I’m assuming that drained the heat exchanger. So check to be sure about power steering and that should do it. Thanks in advanceAyuh,...... What motor is it,..??
Does it have P/S,..??
There should be a drain in the H/E to drain the raw water side,.....
If it has P/S, there's probably raw water in the P/S cooler too,......
I think it’s a full system, small hose off thermostat housing feed the front of the manifold. This is AF going to manifold , vs hot raw water off the heat ex if it were a half systemlooks like a half system (block and heads only)
if so, then the exhaust manifold gets drained along with the tube side of the heat exchanger.
