Winter Project - Middle Bench Seat?
SchofNV
I've been lurking around this forum for a while now, soaking up the wealth of information.
Last night I finally jumped in and purchased my first aluminum boat (the guy was practically giving it away!!). Planning on this being a fun restoration project for over the winter.
It's a 12' 1976 Klamath (see pics).
My plan at the moment:
Empty out all the crap
Fill with water to check for leaks
Buck/replace any damaged rivets
Clean, sand, prime, paint
Build out the rear bench to include storage for gas and battery
Build out the front bench to include storage for life vests and gear
Then to the tricky part. What to do with the middle of the boat?
I have 2 dogs that LOVE to go fishing with me. I'd really like to have the floor space open in the middle of the boat.
I've read about removing bench seats on tons of forums and it seems to be a 50/50 split on whether I should or shouldn't.
Not sure how much the middle bench contributes to the structural integrity of the boat? It's not fully attached through the height of the bench - see close up pics.
If I build a flat floor, raised to the top of where the bench is riveted to the hull (see close up pic) - (don't want to go too high as that could mess with center of gravity and send me (or the dogs) over the edge) - I could use some of the space between the hull and the floor for storage and some for foam (to compensate for lost flotation by removing the bench).
This raises some questions and possibilities:
1.) Would tying the floor framing into the hull maintain structural integrity enough?
2.) Should I add a couple treated wood triangles (kinda like shelf brackets) above the floor each side to tie the hull into the floor higher up without losing too much floor space?
3.) If I built narrow storage boxes down each side, attached to the floor and the hull, would that keep the thing from flexing?
4.) What about cutting out a section in the middle of the bench to create a "walk through" but leaving the bottom 6 inches (under the new floor) and a foam filled box either side?
I get a message saying "You are not authorized to upload or remove attachments" when I try and attach pictures to this post so photos are here:
https://www.dropbox.com/sh/qibfpipf25rl72y/AABJQ2kBNMf-Ezar5m3lDQtBa?dl=0
Thanks in advance for the advice - looking forward to restoring this thing 😁
SOG3
NO treated wood in an aluminum boat period ! Some other members will chime in on the rest of your questions .
