WINTER-izing Let's collect some ideas now
Bob_VT
Okay, don't get mad. So it was pushing 90 yesterday around here but our nights have been rapidly dropping into the 40's and 50's.<br /><br />Let's all put our heads together and put down in writing our winterizing tips/methods. If we "head it off at the pass" we (living in a snow belt freezing area) will establish a reference to go to on our iboats forum.<br /><br />I am speaking of ideas/tips for I/O long tem storage without blowing out freeze plugs, cracking blocks or lower units. Avoiding stale gas, preserving wood trim, avoiding water sitting in the hull, frozen/seized steering and throttle controls, rotting wood..... You can see the list can get long.<br /><br />We have some much knowledge here to put to good use.<br /><br />Lets plan to store so we don't have to plan to re-store in the future.<br /><br />Bob :)
Trent
Re: WINTER-izing Let's collect some ideas now
Move down here and boat year round! :)
Bob_VT
I would love to :) Do you really want ALL of us Northern Boaters in LA (Lower Alabama) :eek: ? <br /><br />Bob :D
bbracken
Thanks for the good idea of posting this subject, especially since this will be my first winter as a boat owner.<br /><br />I have learned that mechanical things, like people, need exercise. I have others talk about rusted or jammed hydraulics, etc. I am fortunate in that I will have access to the boat all winter. Once a month or so, I would like to hook up the battery or a 12v supply and run hydraulic trim up and down. I suppose I should put a heat lamp on the pump first?
Trent
Ok...Bob maybe I dont want ALL of you guys down here. So take a look at this link and see if it helps??<br /><br /> Winterizing Your Rig
Bob_VT
Great wew site Trent! If I ever move to Alabama at least people will understand "Roll Tide" and "Crimson Tide"<br /><br />Bob :cool:
Trent
Whats a Wew....Bob :) <br /><br />ROLL TIDE!!
Bob_VT
wew = web...... stupid keyboard :mad: ! Considering the move as long as it's not to a "dry town".<br /><br />Bob
Trent
Stupid people! We have dry Counties but Wet cities..If that makes since? Dont leave the city or your bootleggin. Then we still have the old guys making the moonshine in the backwoods. Got a love them oldtimers :)
fishlady
heres a question, i've been told that with my bravo II that i can't use the muffs on the lower unit to pull enough water thru the system for running, and for putting anti-freeze thru the system. i was told to go to the water intake hole at the motor and do a hookup there. is this right?
Trevor
Hey you guys talking about a wet city I live in Vancouver BC. wish i lived down south!!!<br />I got lots of tips if any body wantsum!!!!!<br />Just ask <br />Trevor <br />totalmarine1@yahoo.com
Bob_VT
You can rig up a small 5 gallon pail and keep it on the transom. Cut a hole and rig a hose to the bottom of the pail and connect that hose to the muffs. You can fill the pail w/antifreeze and feed it into the cooling intake on the outdrive.<br /><br />Bob
Trevor
easier way to do this so that you dont risk burning your pump out is after draining the block remouve the large hase off your circ pump and pour antifreez down it till it comes out the exhaust or the hose is full also remove the hose that comes from the raw waterpump and put antifreez down it as well. thus no burnt water pump. ive seen people burn more than one pump buy using the bucket method <br />Trevor
flashback
I do my boating in fresh water so salt is not a concern, but I was wondering why some of you suggest putting anti-freeze in the engine after it has been drained?
Trent
Flashback...On one of my personal boats (freshwater) Iv never done the antifreeze thing. Just flush and drain in freshwater. 18 years and still going strong. Just do regular inspections and service.<br /><br />Saltwater guys will be lucky to get six years.. On the manafolds and risers! Little longer on the block. Darn marine mechanics love saltwater!! :)
daveswaves
Ensign
Great idea, here is what i do each year, engine is a 1973 mercruiser, orig lower end, rebuilt engine(lotsa hours). Drain oil out of lower end. this gives me a chance to see if there has been any water intrusion and repair seals over the winter. I leave the lower end empty, no oil. Leave screws in. I disconnect water pump hoses and hose from lower end and pour antifreeze back through the hose until it flows from the lower end. Capture the antifreeze in a bucket and pour it back through until you are certain you have antifreeze everywhere. Pull the drain plugs out of the engine block and the manifold and exhaust riser, drain the water. Put the plugs back in and pour antifreeze through the disconnected hose, back through the pump and fill the block. Pull the drain plugs out again and let the antifreeze run out. Do it again, antifreeze is cheap, blocks are not. I let the antifreeze drain into my bilge and dilute any water that might be there. Then I pull the boat drain plug and let the excess antifreeze run into the bucket.<br /><br />I use plumbing antifreeze as it is environmentally friendly. I grease the lower end and the steering arm and the trailer bearings. Battery boxes and batteries come out, get fully charged, and stored on the workbench in the garage, not the floor.<br /><br />I remove the spark plugs, flood the cylinder with WD40, put the plugs back in. Put Sta-bil or similar product in the fuel tank and fill to 3/4 or close to full for the winter. Last but not least, change the engine oil.<br /><br />In the spring, I put the engine drain plugs back in, change the water filter. I refill the lower end with mercruiser synthetic gear oil. After double checking everything, I hook up the earmuffs, turn on the water and turn the key...then I run in to the garage and get the batteries and try it again! So far its worked. :)
flashback
Thanks for the info Trent, kinda figured I didn't need the anti-freeze as long as i drained everything. the guy that had the boat before me didn't think that way though. I've seen a few cracked blocks in my life but the one I took out of my boat when I got it was a sight to behold, when I pulled the intake manifold and heads off, the block looked like someone took a jack hammer to it. sure convinced me on the winterization theory. happens alot around here though, It's the winter weather. we have a lot of nice days during the winter and folks will use their boats and then gamble on not draining them after each use...
ndemge
daveswaves...
""turn on the water and turn the key...then I run in to the garage and get the batteries and try it again! So far its worked.""<br /><br />ain't that just how it always goes...
sloopy
LOL.. this is why all my motor are pull start
