Winter is coming. How do I keep my old Johnson outboard from freezing?
Halftrack2
New to me 1991 Johnson Outboard tj60tleib. How do I store for winter without freezing? Can all the water be drained out ?
Chinewalker
Store it vertically - self draining. Fog it with fogging oil and gas mixed with fuel stabilizer.
Honorary Supreme Mariner
Make sure there is no water in the lower unit.----If there is water there you need a seal kit installed.
fhhuber
Is there a drain for the lower unit. or drain plug to take out???
Should be 2 plugs that screw in. One near the top of the gear case and one near the bottom.
Put a pan below the skeg and be ready to catch about a quart of oil.
Pull the lower plug, then the upper. (it drains less oil on your hands this way)
Check the oil for water and debris. Should be none.
Check the plugs for metal bits. The plugs should have magnets to catch the metal bits from gear wear. A very small amount of filings is typical from normal gear shifting... but if the magnet looks like its covered in fuzz then something is possibly wrong. If in doubt... don't disturb the filings and show it to an expert.
This is definitely trouble:
Halftrack2
Thanks, I am learning.....slowly....but learning how to care for my boat and motor....
jakedaawg
After you have drained the lower it needs to be refilled with new lube. This is done from the bottom up so to speak. You can get a little kit with lube and a pump. (I gotta believe you could order it and the two little seals right here) It threads into the bottom drain plug. Pump till it comes out the top plug. Place a new seal on the top plug and install, then place a new seal on the bottom plug and undo the pump attachment and quickly screw in the drain plug. It is best not to let the lower set empty for the winter.
Cricket Too
When you pull the plugs out you will see a little white washer/seal on either the plug or sometimes they get stuck where the plugs seats. Buy new ones and replace them every time you change gear oil, they are one time use crush washers/gaskets and will leak if re-used.
