Windows Vista
i386
Re: Windows Vista
I've had a couple of printer driver issues...
One was a HP Deskjet 6000 series. HP just said use the 960c driver and install manually. It worked fine.
The other was a big Toshiba Copier/Scanner/Fax/Network printer thing. There was no Vista driver and I was not able to "make" it work.
mscher
Windows Vista and Turbo Lister 2
If you are an avid or power ebay seller and use Turbo Lister 2, you will encounter problems using it with Vista.
Description builder does not work in graphic mode and application updates will not download, to name a few.
