Yes, I've used the search and read numerous articles/threats about wiring dual batteries with Perko switch. Still a little confused and hope for some direct feedback.
Backstory- Purchased a '89 Stingray a month or so ago. Boat had a Perko switch and 1 battery. Aside from the starter only power needed is for gauges, radio, lights, and bilge. Took the boat out, ran great, parked it, one week later battery drained so it wouldn't start. The switch was in the ALL position and I did not switch to off. Radio memory and bilge were left on on accident.
Bought a 2nd battery- below is the wiring diagram
Unfortunately, all the accessories are direct wired (and fused) to the battery- no bus bar.
From what I understand about wiring, with how I have it set up now I plan on using #1 battery as my starter battery, #2 for accessories.
Questions:
1- What is the best way to charge both batteries while on the water? Will the both charge if in the On position?
2- Should I wired the two negatives together? My understanding is this would lead to me being able to crank off both if necessary.
3- If I wire the negatives together and switch to the Off position, will my accessories still run off Batter 2? Will it be draining any juice from Batter 1?
4- Should I wire the accessories to on of the Perko Switch terminals to simplify the wiring/switch?
Any input is greatly appreciated.
Questions:
