will this hurt the timing
gustafsonerik
125hp force pushing a 17ft bayliner...I notice at wot the throttle plates dont open all the way..Only going about 34mph On the side i see thing that i can adjust the throttle(looks like a tie rod in a car) will this hurt the timing thanks erik
john from md
Re: will this hurt the timing
Since you don't know why your throttle plates are not opening all the way, you should rig the throttle, carbs and timing sync from scratch. The process is spelled out pretty well even in the Seloc book.
Your trottle cable may be misrigged or your throttle/timing bar may be misrigged. Since you don't know what is happening, it is best to start from scratch.
John
