Re: will rts rustolium clear coat work on metal flake fiberglass
As much as I love Rustoleum products, I would not recommend using their clear coat on a metal flake boat. Your boat was built from the inside out. The manufacturer sprayed clear gelcoat into the mold, followed by the metalflake/colored gelcoat and then laid up the various fiberglass layers to give the hull and deck its strength. The clear gelcoat allows the UV rays from the sun to penetrate down to the colored surface and the metallic particles reflect it back through the clear gelcoat, in effect burning it from both sides. This type of finish should be kept covered when not in use and only the best quality synthetic boat polish with good UV protection should be used. It's better to polish these finishes more often as the UV protection in all polishes will degrade over time. Water may continue to bead, but the sun is eating your boat.
IMHO You have three options:
1) Refinish with clear gelcoat. This is best done by a professional skilled in spraying gelcoats, especially clear. This is your best and most expensive option.
2) Refinish with automotive clearcoat. This will restore the finish but since these coatings are quite delicate, especially in marine environments, it will have to be redone every few years and can also be expensive.
3) Polish it with Aurora
Kwik Shine. This is a spray and wipe cleaner polish and a very effective polish on metalflake. This is your least expensive option but will require more effort on your part. You will have to reapply every 3 to 4 weeks to keep it shiny and maintain the protection. The good news is that it's fast and easy. It has good UV protection and regular use will prevent fading.
If you decide to use it, you should scrub it first with a 1:4 solution of TSP to strip the old wax off, followed by a deoxidizer which will remove the chalk.
Kwik Shine will remove light oxidation, but if your boat is heavily oxidized, the dead gelcoat will show through as streaks. Once you have the shine you want, maintaining it is quite easy.
I would start with option 3) If you were not satisfied, you can always go to a more permanent and expensive methodology.
You can also use it on the windscreen, instrument faces and engine cowl. You'll love the shine.
