I have a 1991 48 hp SPL that will only run when choked. Pumping the ball doesn't result in any change. Compression is good (113 and 110) and there doesn't appear to be any leaks in the fuel hoses. I have now pulled the carbs twice and blown each jet with a can of carb cleaner until I see it come out the other end. Float is parallel and drop is ok. Replaced the small circular gaskets between bowl and top of carb. The needle and other 2 gaskets look new. I tried 2 different fuel tanks, one of which I know works. Thanks in advance, John.
