Greetings,<br /><br />I just put together a flounder gigging rig.<br /><br />16 foot Aluminum John Boat. I have a 20 Horse tiller Johnson on it.<br /><br />My questiion is: Is this enough motor to push this rig + two guys (400 lbs.) I can't get it to get up I can only get about 5-10 Mph.<br /><br />The engine seems to run fine but sounds like it is slipping at full throttle. I changed fluid in lower unit, all pins are in and lower end rubberlooks good. I've tried different angle settins on transom. I have 100 PSI in each cylinder and both plugs are sparking good. Is 100 psi good or should it be higher?<br /><br />Maybe Cavitation? Carburation? All help appreciated.<br /><br />The motor is 3-4 years old.
