troyandamyparent
Thread starter- Joined
- May 21, 2006
- 2
My 1995 90hp Force will not go into neutral or reverse.<br /><br />I checked all the linkage, all the way to the lower unit and it seems fine.<br /><br />I took off the lower unit and pulled off the water pump and etc. I can pull on the linkage rod(connected at the bottom of unit) and it seems like it is not connected to anything(other than the swivel).<br /><br />I have also taken off the prop and unscrewed the housing and circle clip.<br /><br />Can anyone tell me how to pull the prop shaft out OR if their is anything else to look at before I do this.<br /><br />What is the linkage screw/pin for?<br /><br />Also, I had some water in the lower unit when I drained it. When I flipped the lower unit over to drain the remainder out. It went into neutral???
