Supersport75
Thread starter- Joined
- Sep 23, 2015
- 1
Hi,
A little over a month ago , I bought a boat with a '90 Evinrude motor. When I went to test the boat, the boat would not plane. Seller then had marina check it out and they found bad gas issues and rebuilt the carbs. Issue still remained and then they found something grounding out or so they said. When I got home it planned fine, but would not idle correctly- seller told me that had been an issue, but not the planning part.
The following weekend I had the boat out a second time and this time it initially idled ok but would not plane until I held in the primmer button . I had to do this for about a minute then boat ran fine the rest of day other than the idling issue.
Because the lines were so old (the marina did find one that was split) I changed out all the internal fuel hoses , the manifold, filter and fuel pump.
This seemed to improve everything as the idle seemed more consistent and only acted up 1 time. I did not have to hold down the primer bulb at all for planing, infact it would make the motor bog down if I did. While it idles fine most of the time, it sounds like it has a slight miss at idle.
In the meantime, a friend calls a retired OMC mechanic friend of his and he tells them these motors have some kind of design defect and idling has always been a problem. I do an internet search and see plenty with the same problems, some from even brand new motors. Some are able to fix them , some are not.
Ok my question is this: Will it hurt the motor to run it as is? I don't want to put a lot of $$$ chasing it down if this is just the way they are . I can live with it, esp if it continues to run like it did last time.
Thanks
Thanks
