The iboats forum moderators are excited to announce that at this time it appears the iboats forums posting pictures function is working once again. Though we cannot promise for how long, we're hoping for indefinitely.
johnson 50 hp vro has small amount of fuel spraying from carbs . question: could bad reeds be causing this ?<br />need input <br /> thanx , skelly<br /><br />------------------
Re: will bad reeds cause fuel to spray from carbs ?
Yes it is common for OMCs two and threes to spit a little fuel back at you.A fuel restriction or weak VRO will animate this phenomena.What symptoms are you trying to cure?
The symptoms are : idels little rough & small amount of unburnt fuel that drips down leg of motor. Not a lot, just a few drips after each outing.<br /> Thanx Skelly<br /><br />------------------
These guys are right about a little bit. If you can see it when look across the carb with the engine idling then it's too much. With broken or chipped reed you will see it easily.
