will 1990 king outdrive fit 1992 king outdrive
chis rick
will a1990 king cobra out drive model#3868074 port shift linkage . has dome top . fit a 1992 king kobra outdrive #987526 with a351omc king cobra motor 584dpeamh transmount 987119 any info would help .
Don S
Re: will 1990 king outdrive fit 1992 king outdrive
For one thing, that is not a 1990 drive. It's a SX Cobra (Volvo/OMC drive) from a 1994 7.4GL with a 1.63 gear ratio.
The drive bellhousing is different, there is no raw water pump on the outdrive, and it has a completely different shift setup. You also need a 1.50 Gear ratio with the 5.8.
The words "King Cobra" doesn't mean much, as there are 3 completely different outdrives called "King Cobra" and none of them are interchangeable.
1. OMC KC with dog clutch in lower. Raw water pump mounted on back of drive
2. OMC KC with cone clutch in upper. Raw water pump on back of outdrive
3. OMC/Volvo KC (aka SX King Cobra) cone clutch in upper, no raw water pump. Shifts like Volvo drives.
chis rick
don thanks for the right info these drives seen to be scarce if you or anyone seeing this reply would know of a1992 cone clutch shift in upper and water pump in upper drive ,king cobra omc please give me a reply thanks for the help .
rodbolt
shoreflyte marine in camden NC used to have a used one on the self.
