I have an older sea ray (73 overnighter) with the 188 hp merc in it. when i turn on the batteries (has two with perko switch) my fuel gauge switch bounces around and my west marine VHF bleeps with the low batterie warning. So i started the boat ( all the other systems work, ie : starter,outdrive trim, etc..) and it still does it even with motor running and alternator running all the systems. also when i turned on the nav lights all the gauges on my panel were flashing slowly (back lights) anyone out there have a clue as to whats going on? i cleaned all the battery terms etc. however there is a solenoid looking thing that has a main lead going to starter and a few other thing that has a little rust on the connections... could this be a voltage regulator of sorts gone bad possibly? Also the alternator has an iternal regulator and i dont suspect it to be the problem as it is fairly new and it does the same thing with the motor not running? any help would be greatly appreciated
Thanks
Thanks
