wide open throttle while not giving it gas
3000gtman
Got this 1980 glassmaster boat. Evinrude 75 sport. Sat for 5yrs. I got her up and running without doing anything but fresh fuel. I had to install the throttle cables since previous owner removed the engine at one point in time. Long story short. I've had the engine running off and on. At first it would fire up and immediately run wide open throttle. I adjusted the throttle cable. Now it's set for low idle but she still fires up and runs wide open...I also just cleaned the carbs but she did this some what before cleaning the carbs too. Any suggestions?
flyingscott
You need to make sure the carbs are completely closed at an idle. Look at the idle screw and make sure it is turned out far enough. You need to make sure the timer base and all the linkages are moving correcly. If it sat for 5 years you probably need to rebuild all three carbs, do a link and sync and replace the waterpump. You need to get a manual for your motor.
3000gtman
I'll get a manual asap. And yes I'm replacing the water pump. I took the carbs off and cleaned them but I'm sure I missed some gunk. Also when starting the boat the front butterfly is open fully unless you push the key in/prime then the butterfly will close but the rear butterfly is controlled by the throttle which is closed while in neutral. This correct?
flyingscott
Yes the front butterflies will be open until you hit the choke then they close and they should open again when you release the choke. The back butterflies are the throttle and should be completely closed in neutral. You would be amazed at how little the butterflies have to be open to make it race in neutral. Try backing the idle screw off until it no longer touches the throttle cam and try it.You also need to make sure the throttle cable is not holding the throttle open, that needs to be adjusted so it pulls the throttle snug to the idle screw itself.
3000gtman
Ok just making sure. I adjusted the throttle cable to close the butterfly more at idle but when I increase rpm she stays at that rpm and doesn't return to idle position without me manually pushing the the level under the flywheel back. Air throttle lever? Not sure what its called.
Silvertip
Honorary Supreme Mariner
Timer base is not moving freely under the flywheel. Ignition timing and carburetor throttle linkage and synchronized and everything must move freely.
hardwater fisherman
No Title
I believe this is what he is talking about. It is located under the flywheel.I think it is for spark advance as throttle is increased.
3000gtman
Ok I YouTube it and saw a guy with similar issue due to the timer base not moving freely. So I tear it apart and clean it up and hope for the best? Or just try to soak it in wd40 or something from the outside?
3000gtman
So remove flywheel. Clean the timer base or just replace it? Like I said it will go forward. Just not completely back to idle on its own. I have to manually push it back to idle. Also if I removed the flywheel do I have to redo timing? Or just simply rebolt flywheel back on?
flyingscott
Where the big bolt goes through the timing and throttle arms spray that assembly out with brake cleaner. There is a coil spring in there that could not working correctly if it's bound up with gunk.
3000gtman
Gotcha I'll try it. If no luck do I have to redo the timing if I remove the flywheel and clean the timer base?
flyingscott
No you do not have to redo the timing. DON'T touch the bolt with the rubber end on it that the timer base hits.
