Why Marine Ties
Dhadley
Re: Why Marine Ties
It's easy to over tighten a metal clamp and cut the hose or crush a plastic fitting. Lots of "stainless" clamps have steel screws which rust. A true Marine tie wrap has a curved part on the lock end. Besides, they're much neater looking.
F_R
Honorary Supreme Mariner
Re: Why Marine Ties
Not to mention cheaper and easier. Fact of the matter is, the clamp is not supposed to prevent leakage and should not be used to stop a leak. The hose is supposed to fit tight enough that it would not leak even if there were no clamp. If you have a leak, fix it with a good, proper fitting hose. Then clamp it. The clamp provides an extra margin of safety, plus prevents the hose from blowing off.
triumphrick
Re: Why Marine Ties
And....I have noticed on some fuel filters and connectors on my Yamahas, a ridge is designed to fit the ty-wrap. A clamp would not fit inside the ridge.
Texasmark
Re: Why Marine Ties
You know, every time I see a hose with a tie-wrap on it, I think of all the time and money Merc spent back in the early days when they used reinforced fuel lines and brass crimped NPT pipe nipples to connect the numerous components in the fuel system. Wonder if the mastermind that determined that ties and regular non-reinforced hose would do just fine got a raise for his idea?
Mark
Mas
Re: Why Marine Ties
Is there an Internet supply selling these Marine Ties cheap?
Mas
bassboattech
Re: Why Marine Ties
these are to be used in outboards not i/o , quicksilver makes them and land and sea dist can get them also
northernmerc
Re: Why Marine Ties
What's cheaper and quicker for the factory? I don't hesitate to replace the ties with good quality stainless steel clamps. At least then one can be quite sure that there is not an air or fuel leak. And clamps make disassembly and reassembly possible on the water.
ezeke
Re: Why Marine Ties
Mas
Any BRP dealer can sell you a package of 100 for list of around .20 each.
lowkee
Re: Why Marine Ties
Jeez, I can't say I would feel comfortable using zip strips to hold hoses on. They are tough as nails and all, but unless you have a zip tie gun handy, I can't see ever getting it tight enough to be considered an asset to any connection. They do make great cable holders, though.
My trusty hose clamps have not failed me yet (besides the occasional non SS one). I agree you must fight the temptation to tighten them to death. A new hose is cheap, a crushed fitting probably isn't.
outboardnut
Re: Why Marine Ties
Lets not forget to talk about application. If it's a large hose you might want to consider a hose clamp. The really small ones you want to use an OEM tie wrap for sure.
Also read the above post twice about the hose creating the seal not the tie wrap and live by those words.
For the small fuel fittings found on johnny rudes those OEM tie raps work great. You can sinch them down with needle nose pliers to a good tensile strength.
I woudln't use or suggest plain zip ties. They don't seem to have the tensil strength of the OEM ones and they don't have the curved end to allow them to tie around the line.
Snapper clamps work well too and are available in different sizes.
