jason32038
- May 25, 2009
- 555
Re: Why isn't my Force 85hp not starting? (In the water)
I was checking out the first pic of the carb and it looks like the float MIGHT BE overbent where it connects to the float needle. This will cause constant flow and flooding due to the needle not closing completely. You can turn the carbs upside down like you had them and blow..if you're passing air then you need to adjust the floats or check needle and seat. Check all carbs...I bent one of my float adjustor thingy mabobs by squeezing the primer bulb really hard when it was already hard. Dont over squeeze when it's hard youre done. Now that I took another look at the pic I cant tell what the hell it is...it's an illusion. Could also be a bad diaphram or hoses.
