tasmania105
- Aug 22, 2010
- 19
I have a 1989 (I believe) Force 85hp that has recently gotten a new water pump impeller and while doing that I also discovered that the thermostat on it had been removed, but oh well on to my concern.
I have been trying to start my Force 85hp and whenever I start it on land with the garden hose it takes a lil while but it will start. But I try to take it to the ocean and after draining a brand new battery the engine will not start, it does crank over and almost sounds like it wants to start but in the end it won't.
Here is what I did so far to diagnose this problem:
1. New spark plugs
2. Checked that the spark plugs where getting spark from all three cables
3. Checked the fuel lines and they seem to be all working fine, all the way up to the carbs.
I'm thinking the carbs may need to be cleaned or rebuilt since the engine sat for a while without being use although I have started before and ran it in the ocean and it also starts on land with a garden hose but it takes a while.
Can anyone tell me what to diagnose next? or what could be the problem?
THANKS!
1. New spark plugs
THANKS!
