Why is throttle gearing skipping teeth?
JohnnyJonBoat
For context: I am attempting to restore a '79 25 HP Evinrude (25904r) to working condition. Also,I am a novice when it comes to outboards so I apologize in advance if I am using incorrect language - just ask and I will be happy to post photos or better explain.
This post is about the throttle. I noticed that the throttle has a ton of slack and needs adjusting (which I am trying to figure out). What has me confused at the moment is how the gearing between the throttle/tiller and the motor appears to "skip teeth". It looks to me like the gearing was installed upside down.
Please see the following video to see what I am talking about. In it, I am simply turning the throttle between low and high - notice how there is a large gap in the gears. Is this something which I can adjust somehow or should I remove the whole tiller handle and reinstall?
https://www.youtube.com/watch?v=eqq874eTNXs
GA_Boater
Welcome aboard, Johnny.
The gears are out of adjustment. When begins to "slip", the flat on the tiller gear can't grab.
Hope one of the Jonny/Rude guys can tell you how to adjust it. It may covered in a manual.
F_R
Honorary Supreme Mariner
Remove the tiller handle. Then rotate the horizontal gear/shaft assembly till the first bevel half-gear tooth meshes with the first groove in the vertical gear/shaft. Rotate it a bit more to get the gears somewhere near the middle of their travel. Now reinstall the tiller, making sure those gears mesh properly also.
