Re: Why Is My Boat Slow
But that ^^^^^ would be below your recommended operating range.
The interesting thing is that a guy at the beginning of this thread recommended that you go to a 21P without having figured out why you are blowing out. The prop shop also recommends that you add pitch also not knowing why you are blowing out.
The fact is that neither of them know until you get some more info. and neither do I. I am not recommending that you keep it as is, but you need lots of info to make a sure prop selection and with what we have here either of those props could actually be slower. I
will recommend that you listen to Dhadley as he knows his ship. More bow lift as he suggests should translate into more positive trim which is another way of saying more trim before it blows out. With the info that is here, THAT is a solid plan . . .
I think I would play more with what you have. Shifting weight around to learn what is, and what isn't, is where I always start . . .
