Re: why do boats have steering on the right?
this is interesting and your theory seem sound, but then I have to ask if you look at a prop airplane most pilot seating is on the left, or as we Say the port. and most props if your setting in the cockpit are turning clock wise. so your weight is on the same side as the prop is turning, that would blow apart your answers just my 2 cents
Gee, now that I've been promoted from a cadet, think I'll try chiming in on this again!
I'm assuming EdTheArcher is speaking of a single engine general aviation aircraft, perhaps a Cessna, Piper or something similar. I actually had occasion to fly one in my younger days and while you could feel the torque of the engine right at start up time, it wasn't much of a factor in flight. Really never had to give it much thought. My guess is it was because the air flow over the wings pretty much stabilized the aircraft.
Regarding trim control, if I recall, we adjusted the trim to keep the aircraft level fore and aft to counteract the nose heavy tendency of the plane and to account for changes in the center of gravity caused by the weight of us passengers and any gear we had aboard. On shorter flights it didn't matter much, but on longer flights it sure helped prevent sore forearms.
Someone also took me up in a helicopter once (one of those small glass bubble types). Talk about prop torque. That's a different matter entirely. There really are no wings. Well, actually, the rotors are the wings. Had to give it lots of left rudder just to keep it in a straight line.
Anyway, that was a hundred years ago, so some of my recollections might be a little rusty.:redface:
