White or Black ????
North Beach
Got the restoration going on my 66 Starcraft Sunchief. We pulled the outdrive off today and it looks like we're gonna blast and paint. It's currently black but my 66 Starcraft brochure and the 66 Mercruiser pamplet I have shows the outdrive being white. Can someone here explain this? I seem to remember someone on another thread saying that Mercruiser has a recommended paint proceedure but that just covers black. I'd like to get this right if I'm gonna go to all the trouble to prep and paint
HT32BSX115
Re: White or Black ????
Howdy,
My dad bought a 1966 Marktwain new. I remember when we picked it up.
The drive was white.
A couple years later Mercury Marine decided that all drives would be black from them on and dad repainted it black a couple years later.
If you're wanting to restore it to "original", paint it white.
Regards,
Rick
jaxnjil
back in the late "80" searay used mercruiser drives and painted them white and badged them as searay.
the paint they used is called oyster white and i got a can from a searay dealer.
the painting porcess for the white is the same as black.
sand any scratches smooth and if you sand the whole drive prime all raw surfaces with zinc-chromate primer. then the cover coat
the only thing i cant tell you is whether or not the oyster white was a searay product or a mercruiser because i have gotten both there and just dont rember now.
here is a pic of part of the white searay drive
ziggy
what drive do you have?
in a quick glanze at s/m #1. looks like the model 0 drive was white.
achris
More fish than mountain goat
Looks like it has flat top cover on the top box... That would make it R, MR, or Alpha One. Definitely not a Model I or earlier.
Howard Sterndrive
he didn't post a picture - that's a reply from another poster guys
A pic of the drive would confirm if it's original to the '66 Starcraft
North Beach
Sorry Folks! I should have posted pics. Here's what's on the boat
Here's what's on the floor:D
The serial # that's under the missing decal is A1955865. I was lead to beleive it was a type 1. Don't know if it's an A, B, or C or if it's an EZ shift. The outdrives are a tad confusing for a newbie. I do know the motor is a 110 HP.
Thanks for the help.
North Beach
Thought I'd bump this back to the top in case it got lost in the shuffle. If anyone knows by sight what I've got and what color it's supposed to be.
Thanks!
Howard Sterndrive
That's the original drive - definitely "pre-pre-apha", or perhaps "0"...
I say black.
Although many were white, I can't believe that one ever was. 66 might've been the transition year.
achris
That serial number tells us it is definitely a model-I E-Z shift, but can't see anything that would tell if it's A, B or C. That said, the original colour was BLACK.
Cheers,
Chris............
Ayuh,... I'd think the folks printing the brochures took Artistic Licence,+ used White,....
I've seen Alot of old Starcrafts,+ None of them had a White drive,...
Your's is No Doubt originally Black...
And,...
As Good a shape as it's in,... No Way I'd strip it to bare metal,...
Just scuff it up,+ use the Good finish that's there for the base...
North Beach
Thanks a bunch folks! I'm brand new to all this and to be honest, there's been a lot of readin done just to get where I am now. The drive definetly doesn't have anything white showing up under the black and it was black when my father in law bought it in 72. I'll take your advice and scuff and paint.
captk
Some of the early Mercs were white. If you get to see an episode of Flipper some of under water shots of the T-Bird show a white merc. Yours is most probably a 1 A B C e-z. The a b c designated gear ration in the upper unit. The mounting gasket on those is smaller than that common to the #1s. Also that does not have a flow through gear case. the upper and lower units must be drained and filled seperatly. The prop shaft is also different from the newer ones the shaft has a square step not the taper, and uses a special thrust hub. Good luck with the restoration looks good. Make sure you get parts and info from someone who knows what ya got. Bill K
oldmanboat
I am restoring a similiar boat. I have a 1966 Shell Lake 120 HP. My outdrive is painted white. I have scraped some of the paint off and see no black paint. I am assuming that white it is the original color.
