Re: while winterizing
Hello all, and thanks in advance for you help. Being a brand new boat owner(this Sat.) we were winterizing the 1972-65hp motor. We had the muffs on with water going through. When we had it running water came out of only 1 hole. not the prop area at all. Is this normal or should I take it in and get it checked. Also we filled the oil from the top screw. Could this make the difference. We will change the oil again and do it the right way. Am I crazy for starting out with such an old motor and not being very mechanical. :redface:
The hole the water you refer it coming out of is the tell tale I suspect (up near the bottom of the engine block at the rear of the motor) Thats a good thing meaning your impeller is working.
With an older motor and not knowing its history, before running it out on the water (perhaps in the spring before the season) drop the lower unit and add a new impeller.
As for the winterization, change the oil out again, filling from the lower hole until it oozes out the upper vent plug hole, change the two washers on the plugs (most common place for leaks) I'd do this after the impeller change in the spring as you have oil in it now and drained the old oil.
Was your old oil milky or was it clear (meaning little use) or greenish/murky colored (meaning it was dirty but not full of water) This is an important step in determining any water leaks in the L/U.
Lastly, as part of your winterization, fog the carbs until is stalls out, pull the plugs and give each cylinder a shot of fogging oil (optional step but takes a few minutes extra to do)
In the spring, do the impeller as mentioned, decarb the engine (search forums you'll find more details on how) and after the decarb, install new plugs.
Welcome to iboats and to becoming a new (to you) boat owner.
